i read this in the forum
http://androidforums.com/zte-warp-n860/684733-i-have-officially-been-throttled.html
Re: I have officially been throttled! i uae root explorer
1-make sure u have ur data disabled or in airplane mode
2-go to root explorer
3-change r/o to r/w(at the top of the screen.
4-Navigate to Data/System
5-Inside Data/System you will find a folder named "Throttle"
6-Long press Throttle folder and select permessions
7-Change permissions to Owner: read and execute only, everything else should be unchecked.
8-when ur done with that press ok and go back to the Throttle folder
9-there should be two files in it(sumtimes only 1,and thats ok too)
10-delete the files from the throttle folder you are in
11-Back out of Data/System to the first menu you were in when you started root explorer
12-change r/w back to r/o
13-exit root explorer and reboot
14-once your phone is up and running,turn your data back on,then your good to go.
you should notice a increase on a speed test. if there is no change you can go back in throttle folder,if those 2 files are back then you prolly missed a step,just go and do the process over again.
i was only getting an average of .26mbps on speed test after i got the text from boost
after the throttle fix im back to my average of about 1.50mbps.not super good speeds,but where i live it good for me cuz the max for me is about 2mbps. A HELL OF ALOT BETTER THEN .26MBPS.
Like i have said a couple times already in this thread..MY CHICKS INCOGNITO GETS BETTER SPEEDS THEN THAT! And thats just SAD AND A DAMN SHAME..
Hope this helps everyone.
heres a screen shot of the THROTTLE folder and the startup directory in root explorer.(NOTICE THE R/O AT THE TOP)(needs change to R/W when you first begin) Just encase there are people new to Android. And especially if your new to the whole Throttle thing.
