mercury0x000d
The ultra-modern operator
Hello, all! Once again here's a tool I made which should help simplify adding a custom boot screen to your ROM. ABSM takes either a 24 or 32 bit image in .bmp format as input and creates a logo.bmp file already rotated 180 degrees, color modified and ready to add directly to your ROM using the traditional method with dsixda's Android Kitchen. It's a DOS executable, so if your OS doesn't run these, you can install DOSBox. Think of the process akin to how the Android Kitchen itself doesn't run directly under Windows, but you have to install Cygwin first to give it the expected environment to play in.
My program is available here and, in the true spirit of open source and community coding, the code is available here.
To run the program, all you need to do is type ABSM and the path to the image file you wish to convert at the command line (e.g. ABSM myimage.bmp) and the rest is handled automatically! As always, I'd be glad to hear any suggestions for new features or bugs that need squashing.
Happy modding!
And as always, please remember that even though I've already done a good bit of bug testing, ABSM is provided AS-IS with absolutely NO warranty of any kind, whether expressed or implied.
If you like my work, or if my tool has helped you out, perhaps you'd consider donating to the cause?
Happy modding!
I kind of figured it had to match the native resolution. I figured it couldn't hurt to ask though
