xmellyannex
Member
Kies recognized my for the first time!
But try Beanstalk. It works just as well on the T model
Where can I find Beanstalk? Sorry I'm being lazy right now. Got to get ready for bed and go to work in the am :/
 )I kind of briefly searched through my EFS... I didn't see anything that locks it to a device... Even the IMEI file simply read "SPR"
Try flashing it... For giggles.
(DISCLAIMER: I am not responsible for bricking of device, though the odds are low in this case... EFS will only stall the boot of a ROM if the partition is unreadable... Then you just reflash the ROM in that case... If it fixes your phone, I am responsible)
https://dl.dropboxusercontent.com/u/1461250/efs.img
O, Thanks. Im downloading Beanstalk and the GAPP and just downloaded your ESF. I'll post what happens!![]()
I do need CWM recovery for Beanstalk correct? Or wil Philz work? Or does it even matter?
I don't think it matters. I have Philz Touch on my phone, and I've never had to change it for all the things I've done to my phone
Ok. So its all on my SD card, wiped data/factory reset, wiped dalvik code, and cleaned to install new rom, then went to install zip and I can't find your efs on there... Ummmmmm.. I must be doing something wrong?!
Im anxious to see the results!
The dialer codes dont work on some roms.http://www.technobezz.com/restore-galaxy-null-imei-and-fix-not-registered-on-network/
I tried to dial some of these to see what it would do. All I got was "No mobile network"
Backup/Recovery > Custom recovery > select EFS
Not seeing any of that :/
I hope you're using Philz Touch 6... lol
Backup and Restore > Custom Restore From * (/sdcard for internal, /storage/sdcard1 for SD card) > Uncheck all and check Restore EFS > Begin
I am using Philz Touch 6. I did what you said and it said, "Nothing to restore"?
Hmm... Okay. Let's take another route with this. Flash your ROM, GApps, and boot up. Install terminal emulator, and we're going to do a custom extract our own way![]()
OMFG! ugghhhhhhh beanstalk is saying....
We don't need to use Kies right? thats the only reason I was installing it and the lag which I can deal with as long as I can just get my phone to work.
No kies lol
Okay, so, no idea what that's about. So, go back to Conquest... I know it sucks, but do it up lol
Now, download this efs.img:
(Different file lol)
Install Conquest, boot. Make sure the efs.img is on your SD card. Open Terminal Emulator, type "su" and grant it superuser.
Then run this command and make sure it is 110% typed accurately. This is the barebones way to do this, but one mistake, and you might flash the wrong partition...
dd if=/storage/extSdCard/efs.img of=/dev/block/mmcblk0p11 bs=4096
This will flash the efs.img file to you efs partition.
Then reboot *fingers crossed*
Right!
Are those spaces in it? or no? Because I put 3 spaces.... ?? If not then thats the problem... maybe!
<<<< BLONDIE
