Well the b07 has the full tether menu it's just locked... if you wanna do your own thing and unlock it go to the system/etc/custom_config/app/secure-conf.xml in the zip before installing it and edit the 0 value next to tether support to a 1 and then install the Rom...Just be sure to do a factory reset before... if you wanna help me out, the only thing that doesn't work on boost is the mms messages and I've been trying make it work on boost... might work might not but it won't brick your phone
http://db.tt/Yo6qjw0S
Also I updated to beta 4 last night with a new kernel and new kernel choices...if you wanna check the Rom thread
