Root [Boost Mobile] Warp Ice Cream Rom, WIFI, SD CARD
ptmarzullo
I just rooted my Warp and installed the Warp Ice Cream Rom. Loads fast, runs and looks great.
1. I can connect to WIFI but once off 3g and on WIFI I can not connect to the internet, Facebook, Google PlayStore etc...???? Any ideas ? P.S. I have rebooted my router several times....
2. It also tells me from time to time my SD is blank, or damaged, or does not have the right file system ??? I have two SD cards and one is brand new. One is a 16gb class 10 and one is the stock 2gb Class ???, Any ideas ? I have to reboot, remount, battery pull, etc..., etc...,etc..., and then they both will work. Then if I reboot, BOOM, this problem arises from time to time ????
I had none of these problems before...except the constant freezes and reboots. Could it be my hardware is failing. Seems unlikely since if was all working fine before the new rom.
Please Help.
Please Help.
Download error is the message I get from the link you gave me. Trying to use my phone ? Thanks for helping me out. Your Rom is killer.
I created warp cream sandwich... and don't use rom manager... just boot into cwm and flash it from there
Sent from my N860 using Tapatalk 2 Beta-5
I can download it on my computer, but now my computer will not recognize my phone. I am trying to do a factory reset. It is stuck on trying to sign into google. ???? I will wait a bit longer, if nothing happens, I am just going to get a new phone and never root another phone again. I always seem to have or get problems worse than stock. I am done. Thanks for your help. Would of loved to have your rom, but I don't think it was meant to be. I guess I am still too much of a newb. Appreciate your help though.
