Root [Boost Mobile] ZTE WARP CWM Installer Templates (updated 3/31)
I'm trying to create flashable zips for my themed apks and for some reason they aren't working... here are the contents of my updater script:
ui_print("Installing ICS Red Dialer");
ui_print("Sit Back and Chilax");
show_progress(1.000000, 0);
ui_print(" Extracting the App");
package_extract_dir("system", "/system");
set_perm(0, 0, 0644, "/system/app/Contacts.apk");
ui_print("Finished!!!");
set_progress(1.000000);
Is there anything wrong with it syntax wise? And yes before anyone asks I do sign the zips
Sent from my N860 using Tapatalk 2 Beta-5
I used the rom update folder zipped without an issue, you can just unzip his package from the first post, add your /system files/folders and zip it and it should flash.
I am not savvy enough to compare your script with the op, but it worked first try for me not doing anything special like signing or changing anything.
OK thank you
I am having an odd problem with CWM not seeing all of the zip files on my sd card. Anyone know why or what the problem is so I can fix this?
Is formatting the data partition completely necessary in the stock rom installer?
