did you try going into the ##3282# > edit mode (you can obtain your password from mslreader from the market) > advanced and change the mms server url to Http://mm.myboostmobile.com also in the advanced menu go to rstp/http settings change the rstp proxy ip and http proxy ip to 0.0.0.0 and the ports for both rstp and http to 0.
hope this helps.
ps if you can't get to the market try using wifi or look for a apk of mslreader on the net.
