Root Boot Animation Help
So I've been at this for a while now with no luck. Would someone please take this .gif and make it a boot animation? I've tried for so long, and it doesn't want to work for some reason. I've gone ahead and attached both the .gif in a .zip archive, as well as what I've done so far, many a thanks will be given to whomever can make this finally work! :)
moved you over to the rooting section. there are plenty here who can help you out with this one.
also you can try following this thread:
http://androidforums.com/evo-4g-all-things-root/320866-creating-boot-animation-start-finish.html
and just saw this:
http://androidforums.com/evo-4g-all-things-root/500118-bootanimation-tutorial.html
Thanks man! I guess I was messing something up in photoshop and using the other applications in the tutorials fixed it!
EDIT: I attached 2 boot animations, one using the .gif from above and the other is the awesome face dancing. Both finally work, thanks again for the help!
