nicholasdarley
of i have read a lot of the same posts as mine, but i want to provided my information on my phone to get help.
HTC Thunderbolt
MECHA XD ENG S-OFF
HBOOT-1.04.2000(PG0510000)
MICROP-/
RADIO-1.16.00.0223r
eMMC-boot
Feb 23, 2011 20:36:02
I am unable to restore a backup using recovery or do anything in recovery because the phone automatically restarts itself before I can perform any action. I downloaded the Firmware that shipped with the phone as suggested in other posts renamed is PG05IMG allowing windows to automattically put the .zip on it so there is absolutely no way it has the .zip.zip i know for a fact it is PG05IMG.zip but my bootloader can not find it no matter what I do and i have tried different firmwares. the SDCARD is definitely FAT32 and i know that i am putting it on the root of my SDCARD.
What i was doing I had Cubed 1.2.3 on there working fine since May. But last night i decided I wanted to go to a GB rom so i downloaded synergy-thunderbolt-unofficial-268 and flashed that this morning well it flashed fine and i was able to boot into it and play around, following their steps I then went to flash the new LTE radio to work with the new ROM cause it requires MR2 or above, but i download the latest version available. I went to flash that using the bootloader like their instructions tell me to do. but it could not find the PG05IMG no update failed or anything like that just couldnt find it well i rebooted and now i cant get past the white HTC boot screen, i can get into bootloader, but if i try to go into recovery it reboots before i can do anything at all.
I hope this is enough information for you guys.
HTC Thunderbolt
MECHA XD ENG S-OFF
MICROP-/
RADIO-1.16.00.0223r
eMMC-boot
it may be fine forever,and it may be a better devices than the crappy refurb youll get from vzw. you may have to send your refurb back a couple times to get one that works correctly. moreso,you may get back an older phone that does have the suspected inferior mmc chips,so if it happens again,the ruu may not fix it.
