Root Boot Manager for Droid X
SimsDelt
Android Expert
I figured y'all would like this... I'm currently running it with Miui as my main ROM and Sensei-Mod 602v3 and ICX as my secondary ones (ROM Slots)... yes if you noticed those are two different ROMs on the secondary (602 and 605) doesnt matter. Only thing that matters is that you are running a GB 2nd-init ROM first as your primary ROM (Phone ROM) and then you can load the others up (the others have to be 602 or 605 ROMs... cannot be Froyo based)(also, some have experienced problems trying to load 2nd-init ROMs into the ROM Slots, but have had success in restoring a nandroid to the ROM slot). Here is the market URL for it https://market.android.com/details?id=com.drx2.bootmanager
I am gonna copy and paste the write up by the developer here as well. I'm not an expert, but I can help with questions as well. Just follow the directions so you do brick and have to SBF.
How to use Boot Manager Basic guide
Online manual for Boot Manager http://init2winitapps.com/stories/BMManual.html
Init2winitapps forum http://forum.init2winitapps.com/
Before starting make sure the following have been met
1. You must be on Gingerbread kernel to use this app.
2.You must be on a 2nd init Rom to use this app, currently GB cm7 or Miui (installing other non 2nd init roms comes later).
3. Make a backup, just in case.
4. Plenty of time, lol.
A few tips to follow.
1. Installing roms can take between 7-12 minutes and restoring nandroids or backing up SD roms can be 10- 20 minutes to complete so make sure you have a full charge
2. Temporarily change the screen timeoutto 10 minutes or never and change it back when it’s done. Sometimes when the screen goes off while Boot Manager is running and has a hard time coming back on when trying to wake it and leave you with a black screen. Only thing you can do is wait it out and if it’s been more than 10 minutes and screen won’t turn back on pull battery and you may have to start over.
3. Avoid using the phone while the app is running (optional, but recommended)
4. When flashing a rom to a slot or restoring a nandroid its best to do it from phone rom and not SD rom. It may not work if you do.
Setting up your Phone Rom ***First and most important step***
1. If you are not on a second init rom start by making a nandroid backup of your current rom, this will come into play later.
2. After you made your backup choose which rom you want as your phone rom, GB cm7 or Miui, you may want to start with GB cm7, you can change phone rom later.
3. After you flashed your rom of choice,GB cm7 or Miui, Set up your phone as normal, restoring apps, accounts, etc.
4. Go to the market and purchase “Boot Manager” if you haven’t already. (If you’re using GB cm7 make sure to flash latest GAPPS first, available in “ROM Manager”.
5. Open Boot Manager, give it root access, and the first thing you should do is setup phone rom before using anyother options.
6. Select “Setup Phone Rom”. It will give you a warning to make sure you’re not booted into one of the SD roms (which you shouldn’t). click “Okay” and proceed.
7. After a few seconds you will get a message saying “Success!!!” and your phone has been backed up successfully. You are now done setting up your phone rom, easy!!!
Installing Roms to slots
1. If you haven’t downloaded which roms you want as your SD roms do so now, these can be 2nd init roms, GB cm7 or Miui, or non 2nd init roms, Apex 602, VorteX, etc. 602 based roms seems to work best, 596 based roms like Darkslide X doesn’t work (for meanyways) but restoring a nandroid of Darkslide X does work.
3. After you have your roms downloaded to your SD card open Boot Manager app then select “Install Zips”. This will show you to all the folders on your SD card.
4. Look for the location where you haveplaced your roms and select the one you want to install.
5. After selecting your rom you willhave a menu with the following.
3 options on top (Wipe System, WipeData, Wipe Cache).
A list of 4 slots.
“Install Kernel” option on bottom (you will not be using this option on the Droid X because of the locked bootloader so ignore it)
6. Check all three boxes, Wipe system,data, cache, and select one of the empty slots and confirm the selection andlet it run.
7. When it’s finished you will get a message in the notification bar saying complete. You can monitor the progress by watching the ongoing notifications in the pulldown.
8. You will want to test it and make sure it is working so in the notifications where it says complete click it and you should get a prompt confirming. Select the slot where you installed the rom, it should have the same name as the roms zip name. If you don’t see the roms zip name in a slot exit the app and open it again.
9. If you restarted the app select “Boot Installed ROM” and select the rom you just installed. It will ask if you want to boot to it, click “Okay” and let it reboot.
10. After a minute or so it should boot into your SD rom. After it boots give it some time to load and then set everything up as you normally would do after flashing a new rom. If it doesn’t boot after 5 minutes don’t panic and follow the steps below.
Pull battery and put back in and power up. It should take you to clockwork recovery.
Using volume key to move and camera button to select choose “Install zip from SD card” then select “choose zip from SD card.
Navigate to” Boot Manager” folder and select it and inside you will see some more folders. Open “phone Rom” folder and select the “update.zip” and then confirm the selection. This will only take a few seconds.
After it’s done go back using the back button and then select reboot now.
If it didn’t install it might be a bad download or it might not be compatible with the app. Not all roms have been tested and most of the 602 based roms do work, some have issues with 605 based ones. Its trial and error from here to see if you can get it going.
If it’s a 605 rom that won’t work install a 602 rom and boot into it to make sure it works and go back to your phone rom and install the 605 on top with all 3 boxes checked, Wipe system, data, and cache. This might work but no guarantee.
Restoring a Nandroid Backup to a slot
1. Open Boot Manager app and select“Manage Installed ROMs”.
2. Select “Restore Nandroid to SD”, it will list all your folders on your SD card.
3. Navigate to clockworkmod> backup and choose the nandroid you want to restore, has to be a gingerbread backup.
4. It will ask you to restore nandroid, click okay.
5. Choose the slot you want to restore your nandroid. If a rom is already installed there it will warn you that it will be overwritten, click okay and let it run.
6. When its finished open notifications with pulldown and select it and it will bring you to “Boot Installed ROMs”menu. Test it by selecting the slot where you restored your nandriod, should have the same name of your backup.
7. Click okay it let it reboot. If it works it should boot up between 1-3 minutes. If it hangs at the boot logo longer than 5 minutes follow the same steps as you would if the rom failed to install. Refer to Installing Roms to slots step #10.
Backing up SD Roms
1. Open Boot Manager and select “Manage Installed ROMs”
2. Select “Backup ROM Slots”.
3. Select which rom you want to backup, only SD roms are available. Use clockwork recovery to backup phone rom.
4. Click “Okay” and let it run, it will take some time to complete. When it finishes you will be back on Manage Rom slots menu.
One last tip
If possible avoid deleting slots that have the image files already setup. Boot manage rtakes the most time setting up those image files. If you can just do the wipes, system, data, and cache, it will reduce the time and can take as little as 5 minutes to install roms or restoring nandroid backups.
I wish they would have come out with this a lot sooner. Now I'm just patiently waiting for my Prime :D:D:D
I'm gonna be the only poor person left here.. I can't afford a new phone... I have to wait till my 2 years is up so.I can get another subsidized one... plus its up 3 days before birthday... so I always know what in getting for my b-day.
I will probably pop in here once in a while too. I'll probably be spending more time over at rootzwiki.com too.
I couldn't find a Class 6 card locally, so I got a Class 4 and the ROMs in the slots are running kinda slow. Would a Class 6 make much of a difference? Does a Class 6 work ok with the X?
Sims a lil birdie (voidedsaint) told me you may be up for some MW3 online. We need to get after it man. VS and I have been playing a couple nights a week this week and last week.
I will be online tonight sometime... if my wife goes into work I will be online around 7 or 8... if she doesn't go in... it will be later... around 10 or so...
i may be on tonight after 1030, the girl im talking to is coming over and we always eat and watch a movie, and she leaves around 10:30, so i will probably be on for about an hour, but when i get home i will def be on :p
Fast cards are optimized for large files written sequentially, (think camera)
For android use, especially roms run off the sdcard like the Nook Color, your best bet (based on benchmarked data), would be the class 4 SanDisk.
This is by far the best app I've purchased. Now I can switch between liquid smoothe, and sensei's rom depending on if im going to be around a charger that day or not. Loving it!
I flashed to 11/05/2011 version of CM7 yesterday and all is great. I have already backup the ROM and installed Boot manager but when attempting to setup phone ROM, its not recognizing that Im on a 2nd init ROM. Not sure what's wrong or how to fix it. Any advice? :)
