Bootloop after flashing custom ROM
Hi everyone, So, wanted to root my phone SGS2, followed the instructions posted on here and all was well, perfect even. Then decided to download a custom ROM, and chose the wicked rom from the list. Copied it to my SD card and used CWM to flash an update. Now handset just loops the startup screens without actually starting. Doh!!!! Could someone please help me get back to the time before the Wicked ROM. I appreciate you get loads of these requests,
Are you sure it's looping? It could take a few minutes to boot as it zipaligns all apps and rebuilds the caches. If it's definitely in a bootloop e.g. no boot after > 10mins then remove the battery for two or three minutes, reinsert it, boot into recovery, wipe cache and dalvik-cache then reboot. Failing that a full data wipe (factory reset) might fix it, but that's obviously a last resort.
To recover the easiest method by far is to restore the CWM backup you made before flashing the custom ROM? You did make a backup, didn't you? If not then you'll have to flash your stock firmware version back via Odin.
Thanks very much for your kind advice. After several hours of panic I found the stock kernel for the phone and reinstalled that using Odin, then re-ran the root sequence that you wrote (CF Root v4.1). So now I think I have a rooted phone with an original kernel. I then copied a few ROMs to my SD card and tried to flash them using flash kernel option in CWM. Anyhooooo, it didnt seem to work, got an error message and option to re-boot. Have now quit in fear of totally ruining my handset and mocking of my spouse who thinks its all bollox anyway!!
Howdie..I m the Dev of WickedROM.
First of all i dont think you have flashed the ROM properly...In CWM recovery,u need to select "flash zip file from internal sd card" then select my ROM's zip file (after clearing cache and dalvik) and then flash.
First boot will take long time.Because its zipaligning for the first time and also an auto EFS backup takes place.You should have been patient :D
Anyways you got a bootloop coz your kernel was corrupted.You could have just flashed a kernel with CWM recovery in PDA section of ODIN.
EDIT
From where did you get my original link.?You should have read the Installation instructions
Thanks to all for your advice. Really should not have started this rooting thing. I have to report that my phone is now completely dead. when the power button is pressed all that happens is the Samsung Galaxy logo appears and then disappears and that's it. Nothing else. Cant boot, cant connect to Odin. Wtf have I done. Please, please help or offer me a fair price for a lovely white paperweight.
Thanks
Can you get into download mode (vol-down+home+power)
if so all is not list. Just re flash in Odin again.
Hi Hawker, no, nothing else except Samsung screen. Green battery shows when plugged into charger but nothing more. Thanks for the reply.
Panic over. Sorry to be such a pain. All good, managed to get into recovery mode and installed stock kernel and then restored. Sweet. Greyer then before. Wife is p*ssing herself.
Happy New Year All
Paul
Happy New Year All
Paul
Lol..Beginners Jitters..Anyways henceforth whenever you are stuck in the samsung galaxy S2 just flash a Kernel with CWM recovery preferrably this www.mediafire.com/?3j4bkfe62acesw9
Have installed DLev ROM and its realy cool, but would like to try something else. Have flashed Evira and Sensation MODs but both just force close my android phone app making them unusable. What am I doing wrong?
Transfer rom zip to your internal sd
power off phone
boot up holding power/home/volume up buttons
boots you into CWM recovery
Wipe Data/factory reset
Wipe Cache
then in advanced
Wipe Dalvik-Cache
Wipe Battery Stats
now install your latest rom
once your in and happy and have got all your apps on make sure you back everything up.
one thing i learnt the hard way is to back your contacts up to google as kies the POS will not recognise my phone, luckily for me the majority of my contacts are on my works phone aswell
EDIT
this wicked rom looks awesome but it keeps restarting and freezing and i really wanna keep it can u help?
