Hi all, thanks again for all the help rooting my evo! I rooted another evo tonight and everything was ok till after i flashed mikg.. after boot up it just keeps force closing everything. I cant use it at all. Please advise.. Thanks
I did both steps twice but the force stop windows are popping up by the dozens
i did the dalvik cache and cache
I think i screwed the pooch.. when i initially went into recovery before installing the mikg rom it didnt have the same options as the evo i did last night. i cant tell you what specifically was different but it was.. should i just start at step 1 for dummies and start over?
When i go into recovery my options are:
reboot system now
apply update from sdcard
wipe data/factory reset
wipe cache partition
install zip from sdcard
backup and restore
mounts and storage
advanced
power off
go back
Does this look right.. should i just start over? if so, should i choose factory reset in recovery? thanks so much for your help!
You nailed it, thats the one thing i didnt do this time.. Ill figure out how to switch to amon ra.. thanks man!
Whelp, you did it again! up n runnin! I guess i can remove the pc36img from my sdcard, what others are safe to remove?
