my lg esteem is stuck in a CWM recovery loop and i get a error every time i try to access the sd card (can't mount SD card)
i was working with [ZVD]Broken Out Esteem 1.1 w/ Blitzkrieg Kernel
please help
Mounting sd doesn work...Well it didnt. Actually (I cant remember on 5.0.2.8) but on touch it mounts the phone in internet mode. Cheapest easiest way is to go buy a cheap micro sd card, put exit recovery on it and flash it.
EVERYONE should to keep the exitrecovery file on their sd cards.
Agreed. There is absolutely no reason not to have it.
I think that should be a sticky by itself. But the thread should be re named. I think it confuses people and they don't know what it's for. "Bootloop" recovery or something simple like that![]()
It can't access internal and external? I'm assuming you've pulled the SD card?
Give the downgrade a try-should bring you back up:thumbup:[GUIDES] Downgrade ZVD/ZVC To ZVB/Emer. PB Recovery - Android Forums
this would help but every time my phone is on its stuck in CWM recovery. to make matters worse not only am i stuck in CWM recovery i can not access my external sd card so i can not use a recovery file or flash a new rom or kernal. i seem to be stuck in CWM and just want to know if i am SOL with this phone and should just get a new one.
Welcome to AF
What do you mean you cant access your sd card? How are you trying to navigate to the sd card in cwr?
get a card reader, that should have been purchase before tampering with the phone, and format it in the pc and put exitrecovery on it and flash it in cwm recovery. BUT if you wipe everything in cwm recovery you will need to flash a rom, so you might as well put a rom on the sd card also or you will reboot to recovery again because there is no OS on the phone itself.
What did you format it too?
fat32 the only other option is ntfs. is there a specific way it needs to be formatted. i have tried everything i can think of.
Yeah it def. sounds like a phone issue.
Have you tried www.androidcommander.com?
Commander can see a phone that is in boot loop from which you can manually edit the files on the phone. I use it all the time when I get in a boot loop from testing out a theme.
What are you using to format it with? I always used MiniTool Partition
looks as though its not recognizing my phone when i connect it.
You tried own ac first and then turning on the phone and hitting refresh on ac?
yeah should it recognize it in CWM recovery ?
