Do you know how to set up Droid@Sceen properly?
I have plenty of experience if you need help.
Yes, some help would be greatly appreciated, i already have the Droid@screen program and adb and all that but i cant get it set up right.
Let me send you a VM670ZV4.KDZ file. Try it with the KDZ. This time with the KDZ use the LG updater app from the KP500 (you should still have it on your desktop, right?). Start it, then close it before using the KDZ.
Will need to upload to my Mediafire account.
Boy! When I get done I'm going to have a ton of stuff on my Mediafire account. LOL
Sorry about that. I have had a whole lot going on over here.
Will try to upload the ZV4.kdz tomorrow.
Do you have the Android SDK setup (path to the adb.exe in your environmental variables and the Java jdk6_u45 installed)?
The fastboot.exe is in the SDK/tools folder. When the time comes you will need to open up a command prompt in the folder (don't cd into it).
What recovery do you have installed?
Can You get into Emergency mode?
This is the situation: adb needs to work to get into the fastboot mode on the phone (adb shell/reboot bootloader). adb is needed to flash a different recovery. If you can't get adb to work you will need to get into Emergency mode and use either the KDZ or KP500 unbrick utilities. Weather your phone is a ZV4 or ZV5, I have the proper LG firmware for those utilities.
Let me know and I'll post the link to the firmware for whatever ZV version you have for both utilities, as well as the guides for them.
[R&D Test Tools Log File]
21:29:31 : Launching SW update
21:29:31 : Unpacking KDZ
21:30:00 : KDZ file extraced
21:30:27 : Files were extracted.
21:30:27 : LGMobileDL Load.
21:30:28 : Port = 0
21:30:29 : Connecting to phone
21:30:40 : Check Phone mode = 2
21:30:47 : Phone type check.......
21:30:53 : LGMobileDL.DLL Loading....
21:30:53 : _SetAuthMark Fail
21:30:53 : _SetAuthMark Ok : wAuthMark(65535)
21:30:53 : _DetachDLL Call
21:30:53 : _DetachDLL Call End
21:30:53 : Param : Path = C:\Documents and Settings\All Users\Application Data\LGMOBILEAX\Phone\ZV5.wdb
21:30:53 : Param : moduleDir =
21:30:53 : Param : waitTime = 0
21:30:53 : Param : UsbHighSpeed = 1
21:30:53 : Param : PhoneMode = 2
21:30:53 : Param : BinVersion = ZV5
21:30:53 : Param : AuthMark = 65535
21:30:53 : Call fn_StartUpgrade
21:31:01 : CDMA: wParam = 20, lParam = 570
21:31:01 : Model Dll Msg Not Found(20, 570)
21:31:04 : CDMA: wParam = 6, lParam = 0
21:31:04 : Step : Main Binary Flash Erase
21:31:04 : CDMA: wParam = 100, lParam = 84
21:31:04 : Step : Upgrade Error2 - Error Code : 84
21:31:04 : ResetStartInfo() Call
21:31:04 : _DetachDLL Call
21:31:04 : _DetachDLL Call End
21:31:04 : FreeLibrary Call
21:31:06 : FreeLibrary Call End
21:31:06 : ResetStartInfo() Call End
21:31:06 : CDMA: wParam = 20, lParam = 0
21:31:06 : Model Dll Msg Not Found(20, 0)
21:31:06 : ===FINISHED===
21:31:09 : OnModelDllMsg(OnMsgFromModelDll-CDMA) delete m_pLGCyonUpdate
23:41:01 : Launching SW update
23:41:01 : Unpacking KDZ
23:41:02 : KDZ file extraced
23:41:02 : Files were extracted.
23:41:02 : LGMobileDL Load.
23:41:02 : Port = -1
23:41:02 : Connecting to phone
23:41:12 : Check Phone mode = 2
23:41:19 : Phone type check.......
23:41:21 : LGMobileDL.DLL Loading....
23:41:21 : _SetAuthMark Fail
23:41:21 : _SetAuthMark Ok : wAuthMark(21364)
23:41:21 : _DetachDLL Call
23:41:21 : _DetachDLL Call End
23:41:21 : Param : Path = C:\ProgramData\LGMOBILEAX\Phone\ZV5.wdb
23:41:21 : Param : moduleDir =
23:41:21 : Param : waitTime = 0
23:41:21 : Param : UsbHighSpeed = 1
23:41:21 : Param : PhoneMode = 2
23:41:21 : Param : BinVersion = ZV5
23:41:21 : Param : AuthMark = 21364
23:41:21 : Call fn_StartUpgrade
23:41:22 : CDMA: wParam = 20, lParam = 570
23:41:22 : Model Dll Msg Not Found(20, 570)
23:41:25 : CDMA: wParam = 6, lParam = 0
23:41:25 : Step : Main Binary Flash Erase
23:41:25 : CDMA: wParam = 7, lParam = 1
23:41:25 : Step : Flash Burning(SDRAM to FLASH)
23:41:25 : CDMA: wParam = 7, lParam = 0
23:41:28 : CDMA: wParam = 7, lParam = 1
23:41:32 : CDMA: wParam = 7, lParam = 2
23:41:36 : CDMA: wParam = 7, lParam = 3
23:41:40 : CDMA: wParam = 7, lParam = 4
23:41:44 : CDMA: wParam = 7, lParam = 5
23:41:48 : CDMA: wParam = 7, lParam = 6
23:41:52 : CDMA: wParam = 7, lParam = 7
23:41:56 : CDMA: wParam = 7, lParam = 8
23:42:00 : CDMA: wParam = 7, lParam = 9
23:42:04 : CDMA: wParam = 7, lParam = 10
23:42:04 : CDMA: wParam = 20, lParam = 507
23:42:04 : Model Dll Msg Not Found(20, 507)
23:42:07 : CDMA: wParam = 7, lParam = 11
23:42:11 : CDMA: wParam = 7, lParam = 12
23:42:15 : CDMA: wParam = 7, lParam = 13
23:42:19 : CDMA: wParam = 7, lParam = 14
23:42:23 : CDMA: wParam = 7, lParam = 15
23:42:27 : CDMA: wParam = 7, lParam = 16
23:42:31 : CDMA: wParam = 7, lParam = 17
23:42:35 : CDMA: wParam = 7, lParam = 18
23:42:38 : CDMA: wParam = 7, lParam = 19
23:42:42 : CDMA: wParam = 7, lParam = 20
23:42:46 : CDMA: wParam = 7, lParam = 21
23:42:50 : CDMA: wParam = 7, lParam = 22
23:42:54 : CDMA: wParam = 7, lParam = 23
23:42:58 : CDMA: wParam = 7, lParam = 24
23:43:02 : CDMA: wParam = 7, lParam = 25
23:43:06 : CDMA: wParam = 7, lParam = 26
23:43:09 : CDMA: wParam = 7, lParam = 27
23:43:13 : CDMA: wParam = 7, lParam = 28
23:43:17 : CDMA: wParam = 7, lParam = 29
23:43:21 : CDMA: wParam = 7, lParam = 30
23:43:21 : CDMA: wParam = 20, lParam = 435
23:43:21 : Model Dll Msg Not Found(20, 435)
23:43:25 : CDMA: wParam = 7, lParam = 31
23:43:29 : CDMA: wParam = 7, lParam = 32
23:43:33 : CDMA: wParam = 7, lParam = 33
23:43:36 : CDMA: wParam = 7, lParam = 34
23:43:40 : CDMA: wParam = 7, lParam = 35
23:43:44 : CDMA: wParam = 7, lParam = 36
23:43:48 : CDMA: wParam = 7, lParam = 37
23:43:52 : CDMA: wParam = 7, lParam = 38
23:43:56 : CDMA: wParam = 7, lParam = 39
23:44:00 : CDMA: wParam = 7, lParam = 40
23:44:03 : CDMA: wParam = 7, lParam = 41
23:44:07 : CDMA: wParam = 7, lParam = 42
23:44:11 : CDMA: wParam = 7, lParam = 43
23:44:15 : CDMA: wParam = 7, lParam = 44
23:44:19 : CDMA: wParam = 7, lParam = 45
23:44:23 : CDMA: wParam = 7, lParam = 46
23:44:27 : CDMA: wParam = 7, lParam = 47
23:44:30 : CDMA: wParam = 7, lParam = 48
23:44:34 : CDMA: wParam = 7, lParam = 49
23:44:38 : CDMA: wParam = 7, lParam = 50
23:44:38 : CDMA: wParam = 20, lParam = 358
23:44:38 : Model Dll Msg Not Found(20, 358)
23:44:42 : CDMA: wParam = 7, lParam = 51
23:44:45 : CDMA: wParam = 7, lParam = 52
23:44:49 : CDMA: wParam = 7, lParam = 53
23:44:53 : CDMA: wParam = 7, lParam = 54
23:44:57 : CDMA: wParam = 7, lParam = 55
23:45:00 : CDMA: wParam = 7, lParam = 56
23:45:04 : CDMA: wParam = 7, lParam = 57
23:45:08 : CDMA: wParam = 7, lParam = 58
23:45:12 : CDMA: wParam = 7, lParam = 59
23:45:16 : CDMA: wParam = 7, lParam = 60
23:45:20 : CDMA: wParam = 7, lParam = 61
23:45:24 : CDMA: wParam = 7, lParam = 62
23:45:28 : CDMA: wParam = 7, lParam = 63
23:45:31 : CDMA: wParam = 7, lParam = 64
23:45:35 : CDMA: wParam = 7, lParam = 65
23:45:39 : CDMA: wParam = 7, lParam = 66
23:45:43 : CDMA: wParam = 7, lParam = 67
23:45:47 : CDMA: wParam = 7, lParam = 68
23:45:51 : CDMA: wParam = 7, lParam = 69
23:45:55 : CDMA: wParam = 7, lParam = 70
23:45:55 : CDMA: wParam = 20, lParam = 280
23:45:55 : Model Dll Msg Not Found(20, 280)
23:45:59 : CDMA: wParam = 7, lParam = 71
23:46:03 : CDMA: wParam = 7, lParam = 72
23:46:07 : CDMA: wParam = 7, lParam = 73
23:46:11 : CDMA: wParam = 7, lParam = 74
23:46:15 : CDMA: wParam = 7, lParam = 75
23:46:18 : CDMA: wParam = 7, lParam = 76
23:46:22 : CDMA: wParam = 7, lParam = 77
23:46:26 : CDMA: wParam = 7, lParam = 78
23:46:30 : CDMA: wParam = 7, lParam = 79
23:46:34 : CDMA: wParam = 7, lParam = 80
23:46:38 : CDMA: wParam = 7, lParam = 81
23:46:42 : CDMA: wParam = 7, lParam = 82
23:46:46 : CDMA: wParam = 7, lParam = 83
23:46:50 : CDMA: wParam = 7, lParam = 84
23:46:54 : CDMA: wParam = 7, lParam = 85
23:46:57 : CDMA: wParam = 7, lParam = 86
23:47:01 : CDMA: wParam = 7, lParam = 87
23:47:05 : CDMA: wParam = 7, lParam = 88
23:47:09 : CDMA: wParam = 7, lParam = 89
23:47:13 : CDMA: wParam = 7, lParam = 90
23:47:17 : CDMA: wParam = 7, lParam = 91
23:47:21 : CDMA: wParam = 7, lParam = 92
23:47:25 : CDMA: wParam = 7, lParam = 93
23:47:29 : CDMA: wParam = 7, lParam = 94
23:47:33 : CDMA: wParam = 7, lParam = 95
23:47:37 : CDMA: wParam = 7, lParam = 96
23:47:41 : CDMA: wParam = 7, lParam = 97
23:47:44 : CDMA: wParam = 7, lParam = 98
23:47:48 : CDMA: wParam = 7, lParam = 99
23:47:52 : CDMA: wParam = 7, lParam = 100
23:48:20 : CDMA: wParam = 20, lParam = 110
23:48:20 : Model Dll Msg Not Found(20, 110)
23:48:20 : CDMA: wParam = 8, lParam = 0
23:48:20 : Step : Phone Reset(DLL Cmd)
23:48:38 : CDMA: wParam = 11, lParam = 0
23:48:38 : Step : Phone Reset
23:48:38 : CDMA: wParam = 20, lParam = 0
23:48:38 : Model Dll Msg Not Found(20, 0)
23:48:38 : CDMA: wParam = 12, lParam = 1
23:48:38 : Step : UPDATE FINISHED!
23:48:38 : ResetStartInfo() Call
23:48:38 : _DetachDLL Call
23:48:38 : _DetachDLL Call End
23:48:38 : FreeLibrary Call
23:48:40 : FreeLibrary Call End
23:48:40 : ResetStartInfo() Call End
23:48:40 : OnModelDllMsg(OnMsgFromModelDll-CDMA) delete m_pLGCyonUpdate
23:48:40 : ===FINISHED===
J
VM670
C:\KP500-Utils-EN\ZV5.cab
VM670ZV5_07
Cool. You can use the "wipe data/factory reset" in a custom recovery, but not in the stock recovery. If you are rooted, you must install a custom recovery and make the all important backup of the ROM. That way you can restore the backup if you or an app messes it up.
Rule of thumb: You can install a recovery from a good ROM, or a ROM from a good recovery. Never a good idea to install an untested/experimental recovery from a beta ROM, or a beta ROM from an untested/experimental recovery.
Look in the All Things Root Guide sticky in the All Things Root sub-forum for the guide on how to install a recovery and ROM. The Bean_Whiz is the best Jellybean ROM, the MiRaGe is the best Gingerbread ROM.
