gallandof
Android Expert
Ive been trying to reroot my droid and get it back to 2.2, i get it to rooted 2.0.1 no issues but when i try to go from there to 2.2 I always get errors in SPrecovery, when i try to do install from SD card i get error 30, when i try to do a backup i usually get and error. I got the backup to go through once but when i try to restore I get error 20. in SPrecovery when I select /mount SD it says SD card can not be found.
In Droid root helper I've mounted renamed installed busybox and flas, ive flashed the recovery, unmounted, synced, rebooted.
seems to go through fine.
then I put the rom I want Kangerades (http://androidforums.com/roms-droid/117131-7-7-10-rom-froyo-kangerade-5-0-9-a.html) green one, I put it in the root of my SD card, reboot to recovery, backup (try to, usually fails) wipe cache, then i try to install ROM from SD card keeps giving error. ( ive tried without wiping cache, with out wiping data and withou wiping both)
and tips? is their something im doing wrong? (first time I rooted and went to 2.2 I had much less issues.
PS: I have also wiped my SD card completely and reinstalled everything (tools etc...)
