Browser Text Too Small? Check here.
Vihzel
Destroying Balls Everyday
Especially when looking at full page views, the text is just too small to read. Solution?
1. Press Menu in browser.
2. Press More.
3. Press Settings.
From there, you'll see Text size as your first option and then simply switch it from "Normal" to Large or Huge. I choose "Large" because "Huge" sometimes makes the text a bit weird because it resizes all of the text and any text in a very small box tends to just stick out. "Large" works just fine. Now the text, even in full page views, is readable!
Thanks, I will definitely remember this when I pick up my X. I was looking at one at the store yesterday and definitely thought the text was small on the screen. Didnt know if I was going to be ok with zooming in and out all the time. Does the text still line up if you double tap the screen so it zoom's direct to the text?
