cool.gautam
Hey all i found a bug on sam's rom " droidmaxxv3" which i posted in comments...
i just mistakely found the solution too...
BUG - There was no usb connection icon displayed on phone while connecting hence u cudn't mount SD card n tranfer files
SOLUTION-
1) connect your A70 to PC/Laptop
2) When charging gets started go to settings --> Applications --> Development --> and UNTICK Usb debugging
3) As soon as you untick that option mobile wil show USB connected in notification bar
4) Now go back to settings --> Wireless & Networks --> Tethering & Portable hotspot --> Then TICK on USB tethering
5) now notification bar will show usb debuuging connected
6) VOILAA>....now u have both usb connected n debugging , u have to do this only first time , after that disconnect and connect u will get the notification as u got in stock
WEll , YOU CAN ALWAYS HIT THE THANKS BUTTON IF I HELPED
SOLUTION-
