Help Bugs After Installing 1.47 Upgrade, Post Them Up!!
kiz88
Only glitch I have noticed is that the battery bar on the top right stays green even when the widget has gone yellow or red.
not sure if this is new or not but if I open a link (set to open in a new window) from something like twitter, it forces me to click on a current tab, then hit menu>windows and then scroll to the right to find the new window
kind of annoying when opening news links from twitter
my battery bar didn't turn yellow until 19%, instead of I think 30%?
Mine vibrated all the time for everything even when I turned it off. However I think it is part of SNESoid and once i adjustd it's setting it was ok.
Im at 22% right now and @ 16+ hours on 1 charge, curious to see when it changes color, doesnt bother me just something for them to fix on a later update.
Very happy with the better battery life also.
My Android System is at 100% awake time now, no more sleep per spare parts...
However, battery life seems to be unaffected by the sleepless phone... Infact Android system actually sits somewhere around 3rd or 4th after the radio idles...
I actually got off scott free with the widgets thing, not a single one haywire or disappeared...
My sister's EVO is also showing no sleep... 100% Android System up time...
my phone seems to take longer when I turn it on from being off. It might be that I love the damn phone so much I'm always adding another app or two.
For a short while..I would try to open up an app on one of my screens and it will pop up with an error that says your screen is too full to add anymore. Weird I would say.
is google talk the issue? after the update everyone was signed back into the service - you need to open it and sign out to stop the process from running
I have noticed that my navigation programs are not operating correctly. They cannot find the satellites or say they have lost data connection and is retrying to acquire. I don't know enough about this thing to say what is wrong but I do know it is different that before the OTA update.
One other thing is that 2 times now in as many days the phone has rebooted by itself while I was on the phone. Never did that before either.
Maybe someone else has seen this?
I dont think i can turn off sense anymore... WTF?
Ditto. Also loaded LauncherPro today and you'd think I had 15MHz processor in my phone. :( Uninstalled. I'll give ADW a shot in a few. But definitely can't run stock Android on the phone anymore. I have options to clear data (big mistake) and force close Sense. Everything else is grayed out.
I had that problem with the navigation as well. i simply uninstalled google maps from the market and reinstalled and it fixed it for me. hope this helps
For some reason, my phone has more lag while typing in websites. There was always a tiny bit, but now it's more noticible? And no turning off sense, or putting up Android Wallpapers.
try using home switcher to go between launcher pro/adw/sense, I updated as soon as the update was 1st available and have had zero problems with any of the UI's. Oh and after the update, was the 1st time i ever tried launcher or anything else other than sense
Switching wallpapers has become a challenge.it always defaults to the rainbow colored one unless I put a live one on then I can put a non live wallpaper
Having WiFi enabled does not allow your phone to sleep. I don't appreciate them "fixing" the wifi reception if it kills my battery now. I never had problems with wifi reception in the first place.
