If its LCD Density you are worried about, buy Root explorer and scroll through the build.prop until you see the number 240. it should say something like ro.build.lcd.density = 240 or something to that affect. Change that number to 220 or whatever, gain more screen real estate. I personally think stock 240 is just fine though.
Good Luck
Has anyone seen a higher than normal battery drain when they have their density changed? Mines been sittin on 190 for a while, but I accidently changed it back to 240 and I had much better battery life. Was this a fluke or truth?
