Not exactly, did you use cwm or twrp to flash it?
I used cwm. Got till fastboot. Pre-bootanimation. Did you get past that?
Don't worry about it! We'll keep trying til we get it. The L90 and other varient phone devs stumbled through at first tooAwesome. Sorry to everyone if I was too quick on the link! This is my first build and I got a little excited![]()
if you have the drive app on your phone click the little diagnal arrow in the top right corner of the web page and open with drive app, then press back the the menu key, then recent, then click the little info (i) icon the click download. hope you can understand that, i couldnt figure any other way to download on phone, so i am downloading on pc, but just did a little test to see if i could help you..? You posted before you tested? I'm all for testing and i don't mind having to redo my phone, but if you're going to post a test I would think you would at least make sure it boots first...
I haven't been able to download on my phone yet, when I try it just shows me the contents of the zip on drive and won't let me download... I am not familiar with drive so maybe I'm missing something but I will probably hold off on flashing until it boots...
Hope that didn't come off wrong and I truly do appreciate your efforts ... Thanks
Did you try twrp and the native cwm we have on the forums? I had luck installing the initial zv4 rooted rom using fast boot but it seems twrp has been the key to installing CM on our phones. I go back and forth between cwm and twrp using flashify and keeping a good cwm backup on my pc on on my sd when I'm testing usually just in case. My isp is taking forever tonight to download your zip but I plan on flashing this in twrp right after it finishes. Bootloop or not I'll let you know what happensSo where do we go from here? I know my way around a *nix command line, but I have no experience with android debugging.
Thank you all so much for your input!
Did you try twrp and the native cwm we have on the forums? I had luck installing the initial zv4 rooted rom using fast boot but it seems twrp has been the key to installing CM on our phones. I go back and forth between cwm and twrp using flashify and keeping a good cwm backup on my pc on on my sd when I'm testing usually just in case. My isp is taking forever tonight to download your zip but I plan on flashing this in twrp right after it finishes. Bootloop or not I'll let you know what happens![]()
Do you have a recommended TWRP? I don't want to lose my recovery just in case...
I also got a recovery.img from the build. Should I try using that?
Yes, here is the link to the twrp recovery
http://androidforums.com/threads/re...-fixed-touchscreen-radio-still-borked.882847/ flash it with flashify from the market and hold down +power when you reboot when prompted and let go of the down +power buttons when you see the factory reset screen come up and go from there. As far as the recovery.Img from the ROM, I personally wouldn't flash it.
after flashing with philz touch i het alot of small text at the top of the screen, its added a few lines since i started typing, but this i what i got [470] fastboot_init( ) [570] USB int ept @ 0xffe0000 [590] udc_start ( ) [720] -- reset -- [730] -- portchange -- [910] -- reset -- [910] -- portchange -- [33360] fastboot: processing commands ... what do you know i got through it all and it hasnt changed at all i dont know if its because i have it plugged into the computer still or not.
alright im no rom developer, but i took a look in the rom file, amd it seems like some pretty important stuff is missing, all the roms i have ever downloaded have a folder inside system with a bunch of apks in it including system, this has nothing inside but a bun folder, like i said im no developer but it seems that stuff is missing from the rom itself. anyone with more knowledge than me wanna take a look. i appreciate everything the op has done but it seems incomplete.
http://xda-university.com/as-a-user/zip-based-rom-tweaking
Dont know if this is relevant but its what i found with a quick google search
