a couple of weeksHow long has it been happening for?
I have the exact problem! Mine is middle of screen right side. My X isout of warranty so no replacement. Have you found any fixes.
No, but my warranty ends next week so I'm sure as hell getting to the VW store pretty darn soon. Did they tell you what the problem is even though they won't cover it? Would heelp me to know ahead of time. Thanks.
You sure your battery isn't bad and swelling? Swelling battery can cause pressure on the screen and cause spots on the screen. Take the battery out and put it on a flat surface and try to spin it. If it spins it's swelled and needs replaced. A good battery is perfectly flat therefore can't spin. This may not be your issue but it can be.
Have the identical prob. Took it to a repair shop. He says LCD screen. 59 bucks. 3 days for parts. 20 min to replace.
