adrynalyne
Android Expert
http://dl.dropbox.com/u/2056318/busybox_1.19.zip
Installs via cwm. This is the latest busybox snapshot from the busybox git. It also supports some things that some other busybox binaries do not, such as crond. There are a lot of commands that are overkill or excessive, but hey, I like my options
BusyBox v1.19.0.git (2010-12-20 01:08:42 MST) multi-call binary.
Copyright (C) 1998-2009 Erik Andersen, Rob Landley, Denys Vlasenko
and others. Licensed under GPLv2.
See source distribution for full notice.
Usage: busybox [function] [arguments]...
or: busybox --list[-full]
or: function [arguments]...
BusyBox is a multi-call binary that combines many common Unix
utilities into a single executable. Most people will create a
link to busybox for each function they wish to use and BusyBox
will act like whatever it was invoked as.
Currently defined functions:
[, [[, acpid, add-shell, addgroup, adduser,
adjtimex, arp, arping, ash, awk, base64, basename,
beep, blkid, blockdev, bootchartd, brctl, bunzip2,
bzcat, bzip2, cal, cat, catv, chat, chattr, chgrp,
chmod, chown, chpasswd, chpst, chroot, chrt, chvt,
cksum, clear, cmp, comm, cp, cpio, crond, crontab,
cryptpw, cttyhack, cut, date, dc, dd, deallocvt,
delgroup, deluser, depmod, devmem, df, dhcprelay,
diff, dirname, dmesg, dnsd, dnsdomainname,
dos2unix, du, dumpkmap, dumpleases, echo, ed,
egrep, eject, env, envdir, envuidgid, ether-wake,
expand, expr, fakeidentd, false, fbset, fbsplash,
fdflush, fdformat, fdisk, fgconsole, fgrep, find,
findfs, flock, fold, free, freeramdisk, fsck,
fsck.minix, fsync, ftpd, ftpget, ftpput, fuser,
getopt, getty, grep, gunzip, gzip, halt, hd,
hdparm, head, hexdump, hostid, hostname, httpd,
hush, hwclock, id, ifconfig, ifdown, ifenslave,
ifplugd, ifup, inetd, init, insmod, install,
ionice, iostat, ip, ipaddr, ipcalc, ipcrm, ipcs,
iplink, iproute, iprule, iptunnel, kbd_mode, kill,
killall, killall5, klogd, last, length, less,
linux32, linux64, linuxrc, ln, loadfont, loadkmap,
logger, login, logname, logread, losetup, lpd, lpq,
lpr, ls, lsattr, lsmod, lspci, lsusb, lzcat, lzma,
lzop, lzopcat, makedevs, makemime, man, md5sum,
mdev, mesg, microcom, mkdir, mkdosfs, mke2fs,
mkfifo, mkfs.ext2, mkfs.minix, mkfs.vfat, mknod,
mkpasswd, mkswap, mktemp, modinfo, modprobe, more,
mount, mountpoint, mpstat, mt, mv, nameif,
nbd-client, nc, netstat, nice, nmeter, nohup,
nslookup, ntpd, od, openvt, passwd, patch, pgrep,
pidof, ping, ping6, pipe_progress, pivot_root,
pkill, pmap, popmaildir, poweroff, powertop,
printenv, printf, ps, pscan, pstree, pwd,
raidautorun, rdate, rdev, readahead, readlink,
readprofile, realpath, reboot, reformime,
remove-shell, renice, reset, resize, rev, rm,
rmdir, rmmod, route, rpm, rpm2cpio, rtcwake,
run-parts, runlevel, runsv, runsvdir, rx, script,
scriptreplay, sed, sendmail, seq, setarch,
setconsole, setfont, setkeycodes, setlogcons,
setsid, setuidgid, sh, sha1sum, sha256sum,
sha512sum, showkey, slattach, sleep, smemcap,
softlimit, sort, split, start-stop-daemon, stat,
strings, stty, su, sulogin, sum, sv, svlogd,
swapoff, swapon, switch_root, sync, sysctl,
syslogd, tac, tail, tar, tcpsvd, tee, telnet,
telnetd, test, tftp, tftpd, time, timeout, top,
touch, tr, traceroute, traceroute6, true, tty,
ttysize, tunctl, udhcpc, udhcpd, udpsvd, umount,
uname, unexpand, uniq, unix2dos, unlzma, unlzop,
unxz, unzip, uptime, usleep, uudecode, uuencode,
vconfig, vi, vlock, volname, wall, watch, watchdog,
wc, wget, which, who, whoami, xargs, xz, xzcat,
yes, zcat, zcip
yes, zcat, zcip
I just clicked this thread again when I heard the chirp/ping of irc. Like I said there Im dragging this morning so I literally just put the 1.19zip on my sdcard and will flashy flash in a minute
