Root Button To Hang Up
armeN0317
Is there an app that changes the end call slider to a button instead. I have an app that has buttons for answering the call but not for hanging up. I also know you can configure the camera button and various other physical buttons to hang up but I'm specifically looking for the slider to be changed to a touch screen button. Thanks in advance!
PS. THANK YOU TO EVERYBODY THAT CREATED THE ONE CLICK ROOT!
You can change it in the settings to the power button. Just click on accessibility then check the box that says "Power button ends call"
As mentioned above I know you can program physical buttons to end the call but I am looking for a way to change the touch screen slider to a button. Before anybody else suggests it I know there is an app to shake the phone and hang up as well.
I have to agree changing the power button to hang up is counter productive.
If I need to dial 1 for english, for example I have to press the power button to turn on the screen if it hangs up the phone it is no help.
