Help Buzzing sound when turn on flashlight
mystvearn
I hear an audible but small buzz coming from the flashlight when I turn the flashlight on. It randomly occurs. Does anyone have any idea what the problem is?
When you say "flashlight", are you using the LED as a camera flash or as a torch? If the latter then it may be overheating or an electrical issue - the LED was never intended to be used for extended periods as a torch.
Other than that, I've no idea. The only similar issue I'm aware of also occurred when the camera itself was activated, and appeared to be due to the AF mechanism.
Using it as a torch not a camera flash.
