Masterchief87
Android Expert
Deleted
Masterchief you think if something is changed in the apns.XML file then we won't have to do all this for tether .... There's a line that is specifically for the tether.
Yeah i use the stock metro tether app airplane mode then start usb tether then uncheck airplane mode i use fiddler for my User agent switcher and i use my adapter to broadcast the usb tether. my alternative non root solution. If you want to add a 3rd alternative i can post the whole process
Forget this . tether is free now , just use built I'm tether appThis is.not working for me at all. Tried several times. I got it to find the network but would not connect.
Yeah metro pc made tether free dudeI'm on s
I'm still on the stock rooted Rom.
Go to the hotspot setting and change the band to.2.4gzIt Wil.connect but no data is being transmitted.
can you use your data on the browser ?I did I have full bars and lte service.
This is my last suggestions because I'm running out of ideas to help you . and
Well reboot system and try again ,
Well I should be sorry should of said that in first place because same thing happen to meIt worked after I rebooted. Thanks a lot. Can't believe I didn't think of that sooner.
Well if youre on the the 50 dollar plan them you share data with hotspot but you can use ( I believe ) a hotspot to hide your usageOne other thing. The hotspot is limited. It quit working a few hours ago. Is there a way to get unlimited hotspot with root.
I can't believe it. I never thought they would start doing this.Yeah metro pc made tether free dude
