Bob Maxey
Android Expert
The only reason it hurts people is because it is illegal. Importation and buying your dope from some criminal happens because it is not available by legal or practical means. By making it easily accessible to responsible adults we are putting these people out of a job, thus making it harder to get for underage smokers.
As for the alcohol, i have some interesting statistics to share with you:
in the year 2000:
85,000 alcohol related deaths
365,000 deaths contributed to poor diet or physical inactivity
32,000 deaths due to adverse reactions to prescription drugs
how many for marijuana?
0 (zero) - and not just for that year. For all of recorded history.
So what other reason would you have for wanting it to be illegal. Acohol is much much worse than marijuana. It seems like your only justification is that you like alcohol. Well, some people prefer a healthier way to relax. Why shouldn't they be able to do it? It's not hurting anyone, and if it does it's SIGNIFICANTLY less than alcohol or prescription drug abuse
I have a stat for you.
440,000 deaths annually from smoking. I am not sure if that is accurate; it came from the American Lung Association web site and as you can guess, they don't know a damn thing about the lungs and effects of smoking.
Your posted stats are useless without explanation and sources. Not everything you copy and paste and immediately post from WrongIPedia is accurate. As for zero deaths due to MJ, God, you are ignorant if you truly believe that cow flop.
By the way, your supposed facts about deaths in the year should frighten you because if you think the stat you posted "365,000 deaths contributed to poor diet or physical inactivity" will lower when the stoner rate increases, you are simple and silly.
Millions upon millions, perhaps even tens of millions have consumed alcohol for a hell of a long time without adverse effects. You can't say the same for MJ use. Smoking is smoking regardless of the plant and despite the utter Cow Flop you have allowed to take root in your brain, saying MJ is absolutely safe is utter silliness because you have zero knowledge about the subject. BTW, I am not an expert either.
Bob Maxey
