daydreamingby
Has anyone tried any call recording apps on the Motion? Care to give some tips? Thanks!
it works on ver e down as of ver f it was taken out. I think scrubs had slipstreamed it into his ver f collab rom with the apk from ver e
One of the features I really miss from Windows Mobile...
I'd like to know as well.
Found this.
haven't tried it out tho
How can android not have this feature and old, really old Windows Mobile 6.1 did? Not trying to be demanding or anything, just curious.
I remember since Gingerbread, I never found a way to record calls since my old LG Esteem.
Is it hardware relates, or software?
There was a stock call recording app?
What's the name of the app called?Yes the stock one in ver d will record calls
Ha.
My Motorola Razor had that feature.
There's a federal law that you must have a beep every 15 secs. and notify the other
Person you are recording, so maybe the FCC discourages this feature ?
lol i wouldn't care if it's legal or not personally. if i want to record a call i will. nobody would know unless you tried to use it in court or something.
I just wanted to report back after having tried this ACR app. In the end, it seems to only record audio from either the the mic or speaker, not both. So imho, it's not any better than any other solution for recording. The upside is that it will automatically delete recordings for you after they are X days old. The downside is that it's also crippleware.
