Posted on the O2 forums site 3/Jan/2010
I forgot to mention battery life...
As long as you makesure wifi and GPS are switched off then battery life should be ok... however I read an earlier post that said that putting the phone in it's nice little wallet that comes with the phone is a bad idea and will cause the battery to drain prematurely.
I too have found the same. Putting the phone into the tight fitting wallet must cause one or more of the buttons to activate and cause the battery to discharge much quicker.
If you are having battery issues, don't put the phone in it's wallet unless it is switched off.
Good Luck, Let's hope the next version of firmware sorts these problems out !
The most appalling problems with the galaxy I7500 I4 (O2)
by steelskin on Sun Jan 03, 2010 4:58 am
mobychick wrote:
Im seriously considering this phone but I have read so many bad things. Is the battery really that bad? Galaxy owners come forward pls!
If all you want to do is browse the web on it, it's fine.... HOWEVER, if you want to use it as a proper phone it has some seriously annoying bugs (I consider them show stoppers). They should never have released this phone like this.
I have now had two Galaxy I7500. Both running the I4 firmware, currently still the official latest in the UK as far as I'm aware. I use my phone mainly for normal incoming and outgoing calls, maybe 10-20 calls per day and for business use so it absolutely MUST be reliable. Browsing restricted to 10-20 mins per day.
Here's my list of problems with this phone, starting with the most annoying, inconvenient and liable to cause the phone to be thrown out the window.
1. This is a BIGGI. Call hangups. It doesn't matter whether it's an incoming or outgoing call the phone will intermittently hang up the call as soon as it's answered or a second after you dialled it. Signal strength is excellent, so has nothing to do with poor reception. This alone will drive you nuts will cause you to hate and despise both Samsung and O2 for allowing this to go on and on without a fix... (workaround, sometimes rebooting the phone will fix it till the next time) .. and sometimes not.
2. Screen lock - This phone seems to have a mind of it's own. It will lock the screen seconds after using it when it's not supposed to, again completely intermittent.
3. It will intermittently flash the screen on and off in the middle of the night. First time I saw it I thought the damm thing was possessed, with some ghostly hand keep pressing the lock screen button.
4. Wifi range is not as good as my laptop. (The least of my problems)
- I've not seen the screen flicker issue myself.
- I've not tried the PC Studio software yet so can't confirm any issues with that.
If not for these problems it would be an excellent phone.
Samsung please get this sorted ! O2 PLEASE APPLY PRESSURE ON SAMSUNG TO GET THIS SORTED !
Anybody from O2, acknowledgement of these issues would be most appreciated. Please don't keep fobbing us off with we are not aware of these issues.
If you expect to use one of these phones for heavy duty business use I would not recommend it until Samsung have sorted the top 3 bugs out above.
