must be a batch of bad buildsReceived my 4th handset yesterday and it also rejects
incoming calls!
incoming calls!
Thankyou for contacting Samsung Electronics UK regarding your i7500 and the recent issue you have experienced.
I am sorry to here that you have been experiencing problems with your new Samsung Galaxy. Any issues with this model are very rare. A firmware update was released shortly after the phone went on sale in the UK and most of the i7500's sold already have this new firmware.
You can arrange a firmware update through one ofour local Samsung authorised service centres. To find the closest one to you go to New URL, click Support and then Service Locations.You should back up anything on the phone you do not wish to lose beforegoing. I suggest that you also phone the service centre before going and take proof of purchase with you. Alternatively you can arrange to postthe phone to us by calling on 08456 726 7864 or to use our online repair service, go to the Support page of our website and select Product Service Request.
I hope this has been of some assistance to you. If you do have any
further queries, please do not hesitate to contact us quoting your 210-
reference number.
Kind Regards
Claire
Customer Communication Centre
Tel.: 0845 726 7864 (All calls chargedat Local Rate)
Homepage: SAMSUNG United Kingdom - Main
[Product] GT-I7500
I'm seeing the same hang up problems. Always had them! Initially I though rebooting the phone fixed the problem. It doesn't! I was expecting a call from a delivery company using a call center (so don't provide a caller id). I was phoned 4 times and couldn't pick up the call. Not happy. I was one of the ones who believed in sticking by this phone and seeing what happens but when you can't even use your phone as a phone it is hard to defend. Samsung need to release an update with at least Eclair fixing all the problems soon or there will be a mass exodus regarding this phone. I'm already eyeballing the nexus one developments. Sorry about the whining people. Guess I've just come to term with the fact that what could be a good phone just ain't delivering!
I think the call hangup issue is a hardware one, I've never experienced it on any firmware.
Maybe an uninitialised pointer in some program that doesn't have an effect until a certain memory location contains a particular value.
I only ever reboot the phone if I need to boot into recovery mode to update Galaxo.
What version are you running ? I guess it's not I4 like me. I'm assuming you have run I4 on your phone and not experienced the call hangups ?
I had I4, then updated to I5, and currently GalaxHero 1.1.1 (which is based on I5).
I have had this issue 2 times. Both times were when the phone was on gsm network, not 3g.
The call rejected when i took the phone into my hand.
I'm running I5 with Galaxo 1.1.1
Up until this morning my phone had been working ok for 32 hours, however this morning it would not make outgoing calls
Then I noticed I had left it on WIFI, switched off wifi and then it worked fine. Could it be a combination of low battery and additional battery drain caused by wifi could cause the hangups
The java implementers however are the ones dealing with pointers, eg. via machine virtual RAM pointers, segmented pointers, 64-bit addressing pointers or handles, since the vm and api are implemented in C/C++
IMHO, it's more likely due to bad shielding mentioned before. Perhaps in your case there is some interference between GSM and WiFi. (?)
