2badmice
I think my flash isn't working on my S4, does anyone have any of the torch apps installed from the market place, are you able to run this app and is the LED flash coming on when you use this app?
I have had 2 replacement handsets from my insurer as the first one had a lens fault whereby a couple of blue and purple lines were displayed on the screen and were appearing on photos.
This handset the flash isn't coming on when taking photos, but the times I've tested it's been daylight.
I've just downloaded some torch apps and none of them are turning on the flash. Before contacting the insurer for another handset I was wondering if anyone would be kind enough to test the apps?
I searched "torch" on the Play store and installed the first 3 apps.
Any help is appreciated.
