My Galaxy GS3 is about 7 months old. The flash has just stopped working properly. When I set it to flash, I can watch and see that the flash does indeed go off. However, it's either too weak or the timing is off, because the photos are very dark as though there is no flash at all. I frequently use the flash in instances where there is a brighter light behind the subject to illuminate their faces. That's totally not working now and I can't get any photos that look good. Does anyone have any ideas about what it could be? Is it definitely a hardware issue - or do you think there might be a software fix.
Thanks.
Thanks.
