Root camera issues mik 3.0
rsoria1
Member
having some issues with my camera freezing up when taking multiple pics. it just freezes up and won't do anything. i have to pull the battery reboot into recovery to wipe both caches then reboot. also when recording a video it records it really "jumpy". not sure if this is the rom or the kernel i am using more freedom and mik 3.0 any help would be appreciated.
One suggestion is to wipe cache and dalvick cache.
I sort of suspect your kernel though. Not that there is anything wrong with it, per se, just they don't all play well with every phone.
One idea would be to do the above wiping and flash a different one.
There is a new sense kernel, by the way.
Another idea would be to just reflash the same rom over itself and it will reinstall the stock kernel. I have done that before and it didn't change my setup at all.
If the kernel is the problem, maybe that will help.
