Help Camera Issues
TexasAg03
Member
Well, in addition to the camera not retaining the resolution setting issue, all of my pictures now come out half done. What I mean is that it looks like part of the photo is cut off. The entire photo shows up in the Gallery preview, but when I view the picture, it's not all there.
What else is going to go wrong on this phone? I'm just getting tired of all the issues. It's very frustrating.
ok you are having issues with your camera? can you post a screenshot of the issues you are having?
have you cleaned the lens off your camera?
do you notice any scratches on the lens itself?
and what other problems have you been having with this phone?
The camera not retaining it's resolution is a known bug. Have you tried a different gallery? You can try the 3D gallery from the market and see what happens.
It's not a dirty lens issue. Literally, half of the picture is gone. I'm attaching a sample.
what other issues are you having? elaborate...
Lockups, crashes, dropping calls, crappy reception, apps that don't work (partly or not at all), poor call quality, the first video I record after a few hours of not using the video function does not save and cannot be viewed, the camera resolution issue, camera crashes requiring a restart. The phone locks up at least once a week when I'm trying to slide the lock to answer a call.
Those are the ones I can thing of right off hand. These problems have existed since day one. Each time an upgrade came along (Froyo then Gingerbread) I thought the problems would go away or improve. No dice.
I've tried rooting and using different launchers. I'm currently on my second phone. I'm done with it and will soon switch to another phone regardless of ETF. I need a phone that works.
