oOMavrikOo
Android Expert
Can anyone tell me where to buy a protective film like we use for the screen for the back where the camera is?
phantom skins do not cover the actual lens, are cut out. If you install a screen protector over the lens, you will want to make sure it is 100% replaceable. Because the slightest dent, scratch, or color distortion problem, and you will need to replace it.
The invisible shield type protectors also slightly distort the camera. I have tried using them, and they do effect the picture.
The best and easiest method I have found for covering the camera is the cheapest, ie thinnest and most flexible, screen protector you can find. Cut it about 1 cm bigger then the camera, and make about 2 or 3 of them. Store the extras in the void behind the battery. If you notice a problem, just peel it off and replace it with a new one. The difference in the picture quality is minor but apparent.
HTC EVO 3D replacement housing available for $80Does HTC/Sprint sell replacement backs? I'd rather have clear pics (w/o a protector) and if something happens just buy a replacement back cover with a fresh "lens".
