) you can download and overclock using tegrak on stock ROMs
I'm kinda reluctant to root as that was the beginning of the end of my old Galaxy S
I just want my GS2 to run at the speeds promised in the specs. I assume it is not as my quadrant score is about 1000 less than everyone else.
What are you comparing it to? My own, admittedly using VillainROM 1.4 but at stock clocks and all background processes running as normal, just scored 3136.
I didn't really mention overclocking. I just want my GS2 to run at the speeds promised in the specs. I assume it is not as my quadrant score is about 1000 less than everyone else.
Slug,have you got any links to root the galaxy s2?as im a newbie but want to give it an attempt!![]()
OK I slightly misunderstood you although, as you will have seen earlier in the thread, the processor speed you have been seeing is as a result of the phone reducing the speed when it's not needed to save power.
My quadrant score was about 3200, much lower than some of the scores I have seen posted and in line with Slug's score above, but my phone is very fast and everything runs very snappily.
If your phone doesn't seem slow, then everything is working fine and I think you are worrying about nothing. If anything does seem slow, it shouldn't, this phone is super quick. If that is the case, make another thread describing the problem and we'll try to help.
As SilverDroid was implying (at least I think you were weren't you?) I think that this "extra speed" is illusory.
I refuse to believe that two identical phones could have such large (3200-4200) performance differences. I think that you should infer from the disparity of results that Quadrant is not a very reliable benchmarking tool rather than assuming your phone is any slower than other SGS2s.
