trippseventeen
the usb port doesnt work on my triumph..how do i flash cwm without usb access?
It might be possible with a terminal emmulator. And it could dangerous.the usb port doesnt work on my triumph..how do i flash cwm without usb access?
I am aware of the risks. whut are the terminal commands?It might be possible with a terminal emmulator. And it could dangerous.
su
mkdir (a directory somwhere, perferably on root (/))
mount (I forget the proper format here, but you want to set it up as the mount would normally be set up. I think it's set up for FAT)
cd (to the directory you made and mounted)
ls (this would show you the directory's contents, which should be /mobile)
cd mobile (or MOBILE)
ls (you should see boot.img, recovery.img and what not)
cp (the location of your custom recovery) recovery.img
I wiggled the male connector inside the usb port around with a dental pick. As long as I use OE cable, I can get usb connected with the cable in just the right position. Not good advice, I know; i am not responsible for any damage!(except to my own phones) but this rescued a 100% dead usb port. no charge, no usb.
Well I'm glad you got something working. You could charge the battery externally, as long as you have a custom CWR you can flash what ever you want. If you need a recovery made into a flashable file, let me know.
That would be great,i'm trying to flash CWM on my roommate's Triumph. The screen is mildly responsive on mine,the usb port doesn't work on his. We both got screwed on that deal..lol
I have Terminal Emulator. I just need the flashable zip you referenced earlier.
Using the terminal is going the manual way of "flashing" stuff. Basically when you flash, the recovery system follows a script. If you are using TE, then you will have to do the heavy lifting.
First, get the recovery you want and extract the recovery.img
Then use the guide that I posted earlier to mount the mobile partition and load the custom recover over. You have to be very careful here as you could brick the phone. I'm thing on my phone so expressing the seriousness it's harder to express.
Ryder, is this ( /dev/block/mmcblk0p1) the correct location?
I was just thinking...
Could he also extract the script from the zip file and run it (slightly modified) with script manager or something... Just to avoid a serious mistake?
Why wouldn't it be as simple as this:
su
dd if=/sdcard/recovery.img of=/dev/block/mmcblk0p1
Assuming recovery.img was extracted to root of SD card.
I wonder if the phone has dd_rescue. [/SNIP]
I hate Linux,lol. why does it have to be unnecessarily complicated?
Ok, this works. I just changed my recovery in terminal emulator.
Extract recovery.img from the flashable zip, to the root of SD card (you can put it elsewhere but for this example, that's where I put it)
I'll explain the lines in parenthesis
In terminal emulator, type:
Su (for superuser permission)
mkdir /sdcard/mobile
(makes the directory "/mobile" on SD card)
mount /dev/block/mmcblk0p1 /sdcard/mobile
(this mounts the triumph's recovery partition to the mobile directory of SD card)
cp /sdcard/recovery.img /sdcard/mobile/image
(this line copies the previously extracted CWM recovery.img to the proper directory of mounted partition, over-writing stock recovery. Proper procedure would be to rename original first as back up)
umount /sdcard/mobile
(unmounts the recovery partition)
reboot recovery
(hopefully reboots into CWM recovery so you can check it)
Ryder, can you check my spelling and stuff? And make sure I did it right. Worked for me when I tested it.
HA, it was the spelling part that I was stuck on when My boss came around.
If it worked I would say that you did it right. I didn't think of mounting it under anything under than root (/). Thanks for the dugh moment.
Now he just needs to get it to stop vibrating.
It did work for me, but you know how it is, trying to type your steps in a message. Easy to miss errors... Especially when using Swype.
The vibrating thing... Boot partition messed up?
It may well be a goner unless the USB port is repaired.
