I'm currently researching Android phones that are below $250. So, I found the Samsung Galaxy S Duos which is affordable and matches the specs of some other low range phones. It has around 4GB internal memory and about 1.7GB is user available.
The interesting part of it is, I want to run some storage hungry apps (Modern Combat 4: Zero Hour - 1.9GB; N.O.V.A 3; Asphalt 7: Heat). As some of these apps require more than the available space on the Galaxy S Duos.
Now,
1) Can we install the apps directly on the SD card and run from there?
2) Or understood it all wrong? If I am, then somebody can please explain with utmost ease?
-Bhavesh
Now,
-Bhavesh
