Apps Can not get acceleration at screen OFF
I make Pedometer app that run in the background.
But I can not get acceleration at Screen OFF in GalaxyS3.
I wanna get acceleration even if device is Screen off.
I tried the following wakelock
 ・PARTIAL_WAKE_LOCK
 ・SCREEN_DIM_WAKE_LOCK
 ・SCREEN_BRIGHT_WAKE_LOCK
 ・FULL_WAKE_LOCK
But,If user turn OFF the screen,the CPU of the device stops.
If, you know when I come Action, Could you tell us.
i have a feeling i heard something in a podcast the other night about user apps not being able to access the accelerometer while the display is off (on stock samsung anyway). They were talking about how samsung's s-health app is ok because it can use the accelerometer as a pedometer in the background.
I could be wrong here though :beer:
Ah, gotcha..so you are developing an app and are having difficulty trying to make it run whilst the devices' screen shuts off and goes to sleep. Correct?
Yes,that's right.
I don't know why wakelock doesn't work.
Anyother devices work wakelock(PARTIAL_WAKE_LOCK)
Thank you, funkylogik.
I think samsung's s-health app that use their Private API.
If it is fact,I can't get acceleration at screen OFF.
But,This app run at Screen Off.I can't understand this mechanism
Runtastic Pedometer
https://play.google.com/store/apps/details?id=com.runtastic.android.pedometer.lite
Welcome to our AndroidForums, miyazaki99.
Not sure what issues you might be having, but I'll try to give you a few tips that might help.
Re. the Runtastic Pedometer app cited above, it uses these permissions:
package: com.runtastic.android.pedometer.lite
uses-permission: android.permission.ACCESS_COARSE_LOCATION
uses-permission: android.permission.INTERNET
uses-permission: android.permission.WRITE_EXTERNAL_STORAGE
uses-permission: com.android.vending.CHECK_LICENSE
uses-permission: android.permission.ACCESS_NETWORK_STATE
uses-permission: android.permission.READ_PHONE_STATE
uses-permission: android.permission.WAKE_LOCK
and the Play Market's Permissions tab does show this at the bottom which is certainly due to use of the above WAKE_LOCK:
AFFECTS BATTERY
PREVENT DEVICE FROM SLEEPING
Allows the app to prevent the device from going to sleep.
Here's simple code that I've used before (it's been a long while, though ;)):
[HIGH] // wakelock-related variables
static Boolean wakelock_acquired = false;
public static PowerManager powermanager = null;
public static PowerManager.WakeLock wakelock = null;
// initialize our powermanager and wakelock variables
powermanager = (PowerManager) getSystemService(Context.POWER_SERVICE);
wakelock = powermanager.newWakeLock(PowerManager.PARTIAL_WAKE_LOCK, "YourAppName");
wakelock.acquire(); // keep the CPU alive![/HIGH]
Also, stackoverflow.com is a great resource for your Android questions (these are the first three results of a Google search using "android wakelock tutorial"):
How to get an Android WakeLock to work? - Stack Overflow
How can I keep my Android service running when the screen is turned off? - Stack Overflow
and this site is awesome, too:
Using Android Wakelock – Staying up all night long | vogella blog
Using the Log method to record some debugging messages I find is always helpful to record events in key places and then view them via a logcat or from the Eclipse IDE's logcat viewer.
Best of luck and I hope this helps!
