Root Can someone help me crank up my 3G?
So I've tried to do all of the 3G speed boost for the admire and I'm getting nowhere. I actually think my 3G got slowers. I'm throwing out only like 50kbps which I know is horrible. Anybody wanna throw out a build prop they think makes the 3g faster for Monster 4.
Yeah that don't sound right. I get around 120kb max. Regardless, Metro 3G is such garbage. Should be called 1x +
Are you on the latest prl? Think it is 3028 now.
Depends on where you stay, I stay in Detroit and its pretty decent on the 3028 prl with the 3g boost. But I have the attain now and the 4g flies :)
For NYC my 1x is pretty much identical to my 3G, I would hope it is because Metro is setting up their signals still, but it wouldn't make sense to have 3G connectivity if it is equivalent to my 1x. I want to try the 3G Boost with QPST but I'm not certain if the 3G is even fully developed :-/
What speeds should I be seeing?
I honestly don't know what speeds you should be seeing just know that they should boost from what you have right now. Tell me your current speeds and what prl you are currently using I would like to make some comparisons.
