Root Can someone help us with this?
Steven58
Former Heavyweight Champion of Android Forums
Moderator
I'm looking for someone to write and maintain a really easy "how-to" for newbies. There's an All-in-one rooting guide that I sticked in the top post, but it's somewhat out of date with the advent of 2.2.1.
Here's what I'm looking for:
1) How can I 1 step root my phone? (give the link for z4root)
2) How can I unroot 1 step... use the same app.
3) How can I restore my phone if I brick (link the files to rsdlite and the appropriate sbf for the build) and give directions. I think the directions in the all in one post are pretty good, just the files are out of date because they are for 2.2
4) What's a rom and how do I update to it? (again..as easy as possible, using rom mgr, let's say, and making sure they have installed droid x bootstrapper.)
5) What's a theme and how do I install over a rom?
That would be it. Any takers? Let me know. If there are no takers I can do it myself, but I'd rather spread the wealth. :)
TIA
Steven
i heard you were doing it Steve!
when its done it should be a must read before any other part of the root section is available. :)
Steven glares at Tom for too long and Tom gets a bit uncomfortable. ;)
Might I ask why another guide is in the works when RoOoLeR's guide is well written and pretty recent?
Good question. I want something very very simple using apps that are 1 click and foolproof.
Makes our job easy.
If this was not in the middle of finals I would put one together. If no one has done it after wednesday shoot me a PM and I'll get to typing!
You're already halfway there! I say just continue with what you have. :)
Of course it will have to be updated almost daily thanks to TBH and the different ROMS and how they work with each new update/etc...
You're already halfway there! I say just continue with what you have. :)Of course it will have to be updated almost daily thanks to TBH and the different ROMS and how they work with each new update/etc...
True
