Matix2600
I have three LG Motions. Two of them are active on the MetroPCS network. Both have Firmware version [F] (MS77010f_01). I use the 2nd Int recovery on both of those and the phones seem to working great.
The third Motion is not connected to MetroPCS and it has Firmware Version [C] (MS77010c_03). I did not get a chance to setup backups with it and I am in a bind here. For some reason the phone will not connect to any wireless access point. I have read everything on the forums and cannot find a solution. The phone can read my wireless router and many of my neighbors but it will not authenticate even to an open network. When trying to connect , it tries to authenticate 2 to 3 times then it saves the network. I will then try to reconnect again and eventually it says network out of range. When I search for networks it finds my router and still will not authenticate. I would like to use this phone to do some testing but I need to resolve this issue immediately.
Has this happened to anyone else?
Does anyone know if flashing a different firmware would help my situation?
Can I dissemble the phone to see if it is a hardware problem?
Comments or suggestions would be very appreciated.
