Root Can't adjust voltages permanently CF.20
jenseits
I'd just recently download the cf kernel 2.0. I liked the lower voltages and being able to customize them. I was using Das bamf 1.6.3, then got das bamf remix 1.7. Now when i try to lower the voltages permanently on boot, the file i edit reverts back. I'm using root explorer which worked fine the last time. Any reason why the setting won't stick?
Ya it's unchecked.
I was having a problem before where i couldn't edit the files at all then i saw about root explorer so i got it. Along the way i thought i read something similar to my issue and they changed the name of the file or something. Couldn't find that post again
