Root Can't connect to USB debugging / USB Mass Storage
I recently rooted and flashed CM7.1. I did something wrong and then reflashed back to the stock EVO 4G rom. After doing so, I can't connect to USB Mass Storage when I plug in the USB cable. "USB debugging connected" comes up on the notification bar and then disappears. I can't access my SD Card to do some needed clean up. Also, My SD Card is at 14.1+ GB capacity right now. If I get rid of my music which is about 10gb on the card, will this help with performance? Should I reformat the SD? Please Help....
welcome to the forums!!!!!!!!!!
try wiping dalvik cache and cache and see if that helps.
and your sd card will really not affect performance unless you partitioned your card and moved your apps to the card. if not then you should be ok. however, making nandroid backups might be an issue.
