Root Can't flash any ROM's
dg61981
Yeah so can't flash any roms using twrp. They all instantly fail and say installation aborted. Bad dl's maybe?
You wanna flash someone named TOM?
:p
Damn auto correct is there any way a mod can correct that title or just delete the thread. I think I figured it out anyways. I'm pretty sure the problem is that I'm running the stock odex ROM and not the deodexed.
I don't have your device so there may be differences I'm unaware of, but I've flashed plenty of roms before on HTC phones and it shouldnt matter if its odex or deodex.
The first rom i flashed on my evo 3d, was the odex, then i went for meanrom, and it flashed with no problems.
So I tried to flash the stock deodexed ROM. I was able to pay a lil closer attention this time and twrp is giving me the dreaded md5 mismatch. What can I do about this? Re-flash the recovery maybe?
Samething happened with me i installed 4 ext and then flashed the touch recovery
If you tell me it's really worth the 2 dollars and change, I'll get it. At this point I'm ready to try anything to get one of these roms runnin
Just give it a try, twrp is not working for you, try 4ext touch, it's worth the money, you could always get it from google search, but i like to buy my apps, for the updates. :D
I picked it up. It's pretty rad. Haven't used it to flash a ROM yet but I did use it to make a backup and let me just say, after using the touch interface, I'll never go back to anything less. It's awesome.
