Root Can't get Crackle to work
sushifor5
So I managed to install crackle last night, but out won't play for me...it just loads continually (spinning wheel) or starts then stops.
I am on harmonia rom, have installed adobe flash, am overclocked to 746 (or something like that?) and using 3g...no wifi here.
Any suggestions? Are there other apps or web sites that are more stable for streaming video on our OV?
Tia!
The only way I could get crackle to stream properly was with Skyfire browser, and it was a bit tricky.
I have it working but it is very touchy sometimes if you tap the screen then the time bar comes up move forward about 5 seconds then it runs. Skyfire does work best but you have no control such as pause and rewind.
The last time I tried it was a couple of months ago, before I learned the correct CPU voodoo for my phone. I may try again, now that my phone is so much faster now.
