Root Cant get flash player to work on prevail, please help.
jackbquick123
I have a rooted stock Galaxy Prevail with gb update. I have read and read and then read some more and tried everything and I cant get adobe flash player 10.1 or 10.2 to work. I make sure and reboot after install, i installed blade buddy and turned on media.stagefright.enable-player and meta and tried it enabled and not and everything I try it still doesn't work. Am I missing a thread or just not doing this right.
Any help would be appreciated.
Thanks for all the great info here ,, this is the best place to be.
thank you and yes that's the file I have been using.
It Down Loads and Installs great Tiny Shark shows it installed but will not work.
I think tiny shark is about the best sure fire way of knowing. Its detects mine and says its installed but doesn't work.
Was just hoping someone had some info that I hadn't seen yet.
Thanks
Nope. Didn't work. I put it in system/app/ its there and titanium backup shows it but it don't work. To bad cause the video I picked to test it on looked like a damn good interesting clip :D
Still not working just hoping someone has a new trick or advice on this.
Cos would really like to get this working.
Thanks everyone
