Help Can't get MMS to work
piannetta
Member
Hi, I'm in Australia on the Optus network (I'm not sure that matters, but I'll mention it anyway) and I just can't seem to get MMS to work.
I've trawled the web, found heaps of posts for the settings, tried them all, any time I try to send or receive an MMS, I get a "general network failure". All other things work perfectly.
Am I alone in this or has anyone else had the same problems, and more importantly, know how to fix them?
Cheers,
Pete
I had exactly the same problem with my desire on vodafone in the uk. I searched the vodafone forums and found out vodafone had been selling unbranded desires with the wrong apn settings. I found a post on the vodafone website and now everythings working ok.
If it's anything like T Mobile in England, when this problem occurred it was solved by changing the maximum message size to 300k in the settings.
Cheers,
Pete
Hey Pete,
Not sure if you are still looking for the fix but most likely are as it took me a few days to find it. It was posted here and this worked for me. Simple enough without doing a factory reset. I had mucked with the APN with an attempt to put in a mobile on/off switch app for Sense which didn't work (not Quick Settings).
Third post with the steps in it worked for me. I would look for APN for your Desire and Phone service. Good Luck.
http://androidforums.com/support-tr...ck-settings-bug-mobile-data-switch-issue.html
Hi,
I think I have a similar problem but I'm on Orange in the UK and whenever someone sends me an MMS it says to download it but it tries and fails. When I try to send an MMS the same thing happens, tries but fails. I'm using Handcent and Launcher Pro Plus by the way.
I am not techy and just looked at the APN stuff as listed above, in APN via settings I have "Orange Internet" (highlight green spotty thing mext to it), "Orange MMS" below it and then beow that another "Orange MMS". Within both Orange MMS the APN is set simply to "orangemms". I don't want to start tinkering with things if they're different as I wouldn't know how to get back.
Any help would be much appeciated if it's different to the above. :confused:
Hey Pete,
Hi Tyrolis,
Thanks for your advice, I tried it and unfortunately no difference. But thanks for the tip on APN Backup, handy little program.
Pete
My Desire is on Telstra in Oz, , and I ported from VODA, , that was the issue. I could only MMS telstra numbers, but not voda or optus.
Did you port from someone else ? Or get a new simcard ?
Craig
Hi,
I had the same problem, i went into the Orange MMS settings and changed the authentication type to none, i think it was set to chap. Anyway after i did that, it works perfectly.
Hi,
Here is the orange settings
Apn: orangeinternet
Proxy: <not set>
Port: <not set>
Username: <not set>
Password: <not set>
Server: <not set>
MMSC: <not set>
MMS Proxy: <not set>
MMS Port: <not set>
MCC: 234
MNC: 33
Apn Type: <not set>
Apn: OrangeMMS
Proxy: <not set>
Port: <not set>
Username: Orange
Password: Multimedia
Server: <not set>
MMSC: http://mms.orange.co.uk/
MMS Proxy: 192.168.224.10
MMS Port:8080
MCC:234
MNC:33
Apn Type: <not set>
But i have my username and password as not set.
Apn: orangeinternet
Proxy: <not set>
Port: <not set>
Username: <not set>
Password: <not set>
Server: <not set>
MMSC: <not set>
MMS Port: <not set>
MCC: 234
MNC: 33
Apn Type: <not set>
Apn: OrangeMMS
Proxy: <not set>
Port: <not set>
Username: Orange
Server: <not set>
MMS Port:8080
MCC:234
MNC:33
Apn Type: <not set>
Hi mate and thanks for getting back to me. I've just tried adjusting the settings according to what you have above but still it doesn't work :( I can't send or receive MMS at all. I've been on to Orange a few times and it is all set up as far as they're are concerned, but all they ever seem to do is to run a diagnostic and if they can't work out what the problem is they recall your handset and send you back to square one again. Hasn't got to that stage yet but I returned 3 Vivaz handsets before getting the Desire and I'm not happy in sending this one back as it is unlikely a handset issue.
It's really starting to bug me now :mad: :(
Hi, I'm from Finland and I've exactly similar mms problems as who started this.
My problems started after 2.2 update...
I have no idea then, as i said before all i did was change the authentication type to none. Have you got the username and password set to none as well?
Craig
Hi Craig,
No, always been Optus, same SIM card & account as I had on my old WinMo device where MMS worked fine.
Cheers,
Pete
I seem to recall a member saying you must remove the Proxy from the APN settings. Dont recall if this was the internet or MMS APN. Worth a go, as sounds APN related rather than phone or SIM.
Mmm, thanks for the suggestion but it didn't work for me
I think I have to make a recheck... has my friend received any mms I send, because phone didn't give any errors when i used an old fw 2.1
I just assumed he has got them. (yes he did, I just received a phonecall from him)
I think it's not a settings issue... I would blame a froyo.
I don't have Froyo yet, I'm hoping Froyo will fix it!
