Help Can't load Android system.
Leyna
I started getting this message everytime. Nothing works so far. Maybe I'm doing something wrong? Is there some way to fix it without factory reset?
what did you do to get the device into this situation? is it rooted? did this happen randomly? after an update? just remember the more info you provide the better we can help.
you may want to look into flashing a firmware update. not familiar with lenovo devices, but this may delete data.
I don't remember exactly. My apps were working slowly, I remember I was trying to make screenshot of something but for some reason it didn't work and I've been redirected to google photos. Thought it was because it wasn't updated so I updated it and few other apps. Tablet was still freezing so I decided to reboot it. Then this happened. Don't think my device is rooted. Tried once but I think process wasn't finished so it's probably not. Never had much problems with it untill now.
well it sounds like the os got corrupted.........and thus i think your data is gone. no way of retrieving at this point. might as well do a hard reset and see if you can get the tablet to boot up.
