What radio do you currently have? Im not sure Froyo works on a DI01 radio. Also fwiw in the future you dont have to odin to go from jt's vanilla to get back to 2.1. You can merely triple wipe and flash a dj05/dl09 rom and kernel. I did worked flawlesslySo I flashed jt1134's Alpha Froyo correctly. Everything worked in that. Then I used the All In One DI01 to flash back to stock. And SMS no longer works. I flashed BACK to Froyo and SMS texting doesn't work in that either. WTF? Help?
You need to odin the radio, either dj05 or dl09 will be fineHmmmmm. I don't think my phone likes DI01 at ALL. I was on DL09 with a DI01 radio a few minutes ago and it wouldn't do ANYTHING. Then I went over to Froyo with DI01 and the same thing happened. I just flashed to DJ05 rom and kernel but the baseband radio STAYS at DI01. What can I do to get it to DL09?
Oops sorry I copied the wrong thing. Here is DL09 radio : http://adrynalyne.us/files/roms/DL09modem.tarCan I have a direct link? Can't seem to find it. :/
Correct, must odin the radio tar, just do it when you get home then I guessSo theres no way other than Odin to do this? Lol.... at girlfriends house with no USB phone cable.
Correct, must odin the radio tar, just do it when you get home then I guess![]()
ProbablyAlright. Appreciate it Saps. I'm sure many people will be happy to see this when/if they do a search and come across this thread.
Worked perfectly. Thanks again.
sweet
