the no file or directory worries me. the output needs to match what is shown in the guide
I think windows will hide the .img extension...and yes, its smallYes... I copied it to the SD and when I went to look at the original copy on my computer, it didn't have it labelled as an image or .img file..
is the file size supposed to only be 1kb?
my extracted file was only 1kb also...the extracted part of itno it should be like 640 kb or so
http://dl.dropbox.com/u/58324641/mtd-eng.img
If you want, delete yours, download the extracted file in my DB like you did with the flash_image file...
How far back do I need to go? start back from the "adb shell cmd"?
when I opened that link it gave me a weird looking error mentioning debugging cable... is it safe to close cmd with exit cmd and switch my phone over to hard drive?
your link sends me to a website and this is displayed on the web page...
SPCS_001�
SPCS_001�
Should I reboot device now and then shut it back down, or if I select no, can I go to the fastboot screen and run unrevoked?
I selected no to the restart and now it's updating again...?? should I just boot it up and then shut it back down and go into recovery and create the nandroid back up?
Is is safe to remove any of these files from my sd card now?
It appears the custom recovery did not install.when I try to boot into recovery.... there's a picture of a phone with a red triangle and an exclamation point on top of the phone's top right corner.... I don't know what this is.. sorry I'm such a noob.. lol
It had to have installed though... I used it to select the superuser.zip, right??
Yeah, that's what is befuddling.It had to have installed though... I used it to select the superuser.zip, right??
Yes sir.I should use unrevoked3, right?
